Well I need to get a different oil pan for the conversion
Sent from my XT1254 using Tapatalk
Does yours look like this one?
If so no, you don't. If it doesn't then yes you will. For a foxbody Mustang.
Plywood.....jk, after looking at my mounts, 1/4 -3/8 Inch steel plate should be enough to make those mounts. My next swap will be done with these fabbed plates instead of the kit variation for sure.And what material should i use to make those brackets?
Do these headers fit inside the engine bay? or would i have to go to the shorty versions?
with the motor mount plates, is the height supposed to be adjusted with a bushing?
What are good 4.10 axels to swap in?
