- Nov 30, 2001
- Gnaw Bone, Indiana
- Manual
This post is so packed with misinformation I'm tempted to blow it in place.
An FMX is not as strong as a C6. And FMX is the ancestor of the AOD and the C6 is the ancestor of the E40D.
A turbo is not a high rpm performance boost. That's exacty what it is not. It does not kill your low rpm power and lag has nothing to do with low rpm power. A 2.3 turbo puts up similar numbers in the same rpm ranges as a 5.0 HO--and it's half the size. All lag is is the delay between the time you stomp on it and the time the turbo spools. If you size the turbo too large your engine won't be able to spool it up at low rpms. Most of the time the turbo is sized fairly small so it spools up quickly and then is equipped with a wastegate to keep it from over speeding. The turbo gasser cars I have driven--a Dodge Daytona, a Suzuki Swift and another Dodge sedan of some type--they all had a bit of a lag--about a quarter to a half intersection worth, then took off like mad. If you boosted a 300-6 it would spool up at a low rpm with the correct turbo. Especially with it's long stroke which already moves a lot of air at low rpms. You need to get the turbo selected for you by someone that has access to the turbo maps--three dimensional drawings that show boost and turbine speed over a variety of conditions. If you were in known territory with lots of empirical example then you could forgo that step.
The 300 does not have great low-end torque. A 460 has great low end torque. A 300 makes what torque it has at a low rpm. It has to, because it only has 300 cubic inches. You put your troops where they will do the most good and if you are going to have a chance with only 300 cubic inches, it needs to be right off the line. After that, it's going so it doesn't matter.
Jamming that long thing in a Ranger is a waste of time. A 302 is a better choice. It fits easily and can spin faster. It makes more torque--about 40ft# more at the same technology level. That's because a 300-6 is tuned so hard to run at low rpms that the air is restricted. Everyone seems to forget that air is the hardest thing to get into an engine. The fuel is easy and the spark is easy. The air is the trick. A 300-6 in any configuration has a long passage to fuel the outer cylinders. The air is a tough thing to get through in one piece. The theoretical vs. actual is what people call the volumetric efficiency and the 5.0 is much better at it. A 4.0 will outflow a 300-6. The horsepower numbers prove it. You gear up the difference in torque. A ship with a jet turbine engine definately has gearing like crazy. Your after raw horsepower. Use the gearing to adjust it. A 300-6 is a novelty installation.
But, now he says the rules have changed!
