3 inch body lift problem clunking
Ranger Business
i finished my body lift on my truck and turned it on and it idled perfect. i droped it into reverse and it made a clunck sound, then again in neutral, and again in drive. then it barley has any power in drive to go anywere cant even get up my driveway. so i backed up and that backed up fine. anyone know whats wrong???
check to see that you didn't pull any of the electrical connections apart while lifting the body.. other than that a body lift really can't affect that much
Standard or auto?
Standar, you might need a shifter extension. Auto, is it possible you may have streched or mis-aligned the a shift linkage?
And also what was said about checking elec conecctions....
