holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
I have had KOER codes 12,74,and 77, I can not get rid of them. first #12, The computer says that the idle is too low, It idles right at 850 rpm, tps voltage is 0.948 volts at idle, TPS is new (flat voltage in center of travel with the old one). #74 I am pressing the brake after the engine id is received, the brake lights are coming on as well, there is little resistance across the switch terminals when the brake is pressed. Would having LED tails cause this? #77 I am pressing the gas to the floor when my code reader tells me to (blue point YA3140). I checked to see if the throttle goes to WOT with the gas pushed to the floor, it does, is there a way to tell when to snap the throttle, either by waiting a certain amount of time or listening for the engine to make a certain sound? This is on my '86 so there is no check engine light to watch for blinks...
