treeguy
Have a 1990 ranger 4x4, ext. cab, 2.9L, want to put on a body lift, and I found one on Suspension Connection, do I need to extend the 4wd shifter too? Any other thoughts on this would be good . . .
also some of the bolts they sent me were a little to long, and others seemed to short. also a big pita.
I had a couple of the early Rangers and Bronco II's that I put suspension and body lifts on. I only use Performance Accessories bl kit. I got everything I needed for my upgrade. Bumper relocation brackets as well and the gap guards. You will be happy with PA. I think you can still purchase the bl here on this site. Look into it or call PA about it to make sure before you order a kit.
Good luck, Bro.
No regrets on the 3", I would do it again in a heartbeat.![]()
no i did not. all the bolts were the same lenghts. they were to long for all the mounts exept the two in the rear, and too short for thoughs two mounts.You used the wrong bolts in the opposite spots! .
I am confused about this. I have done over 20 bl kits with buddies who helped me or I helped them over the years and I have never come across this issue. What kit did you use?? Was it a home made kit you got from somebody or did you buy it?
How would one make an extension for the 4wd floor shifter? Thanks for all the input guys!![]()
