3" body lift help
jake122288
good old pleasantville, Iowa
I ordered a used Performance accessories 3" BL kit (kit # 793) and i went ahead and downloaded and printed off the install instructions from performance accesories. but it doesnt specify which brackets are for what. im sure i'll feel dumb after someone tells me but i guess i'd rather feel dumb than not do something right...
circled in the pic are 4 brackets... the two with the bolts sticking outta them i have been told are the radiator drop brackets (according to the instructions u only drop the fan shroud) so if that could still be cleared up a bit thanks too...as for the other 2 brackets circled i have no clue...so if u know please let me know! Thanks!!
The two with studs are rad drops or electrical drops(some models use those same brackets as electrical extentions.
The one to the left of those ones with the studs is the ebrake cable bracket. I know on Rangers, you don't even need to mess with that...I've never messed with it on the 4 98+ ranger bodylifts I've done.
The one on the right...absolutely no clue.
Check out your instructions for the kit's content list....should be able to figure it out.
oh and yes i failed to specify this is for my 94 explorer! as for my parts list in the instrucions it only says (referring to brackets and what not) 2x fan shroud drop bracket (i got those figure out now, but do i drop the whole radiator, or just the fan shroud), 1x steering extender ( i know this one) and lower fan shroud support... (no idea, but assuming now its the one to the right), and it says nothing about that other bracket which would be to the left in the pic?
