Found! 3.73 ring and pinion for Dana 35
aj351w
Law Enforcement
Frankston, TX
Putting a Dana 35 from a 93 Explorer into my 89 Bronco II and need a set of 3.73 gears. Anyone upgrade and have a stock set laying around?
Where are you located? I have a whole rear axle
I’m in Frankston TX. I have an 8.8 rear end with 3.73’s and limited slip from a 2wd Explorer. The 4wd Explorer I’m using for the front has 3.27’s and open rear so I’ll use the 2wd’s rear and just need to replace the Dana 35 gears to match the rear. Long story short I just need front gears to match the rear.
