3.5 ecoboost 2nd gen ranger 4x4
twoll86
U.S. Military - Active
caseyville,il
Just looking for information as of right now.
What i know thus far;
Ford makes a stand alone harness for use with 5 speed/mechanical auto
Quick time makes a bell housing(i believe that they would make a custom one for the ranger)
M5od- hd would probably be best for the power.
I believe that a 5.0 or SOHC 4.0 radiator would be sufficient to cool the beast.
3"body lift will probablybe required
What can anyone tell me beyond this or correct if im mistaken
Depending on use the M5 may not be ideal and the bell housing is not removable.
Hmmm i thought they were welp looks like itd have to be the the early mits trans or an f150 5 speed
Evidently the ecoboost 3.5 shares/ uses the 3.5 duratec block if thats true a ranger 3.o shares that bell housing correct?
88-08 F-150's used the M5ODR2.
Biggest problem with them (aside from the bellhousing ordeal) is they are too much of a truck trans for racing and too much of a car trans for heavy towing with ample power.
No idea, keep in mind you will be running much more power than the designers of the 3.0 Ranger transmission dreamed it would ever see.
Why not use a T5? Quads4Rods and Quick time make duratec to T5 Bell housings
The t5 isnt 4x4 and advanced no longer makes the adapter for to make it 4x4
84-87 f150s had a removable bellhousings on the 4 speeds or i could try a zf
