I noticed the valve springs looked very similar to a set of smal block chevy valve springs I had sitting on my shelf. The diameter and the install heigth are the same and they produce about 25% more preasure at the seat then the stock spring.
Were those the 3.0 Beehive spring heads or the regular coil? Anyway that is good info.
JP02XLT
What's wrong with OE replacement ones?
I needed stiffer springs for the blower, it would blow them off the seats & start floating the valves at 13-14 psi. The stock springs, even the beehives are very light pressure for a valve spring.
JP02XLT
