3.0 to 4.0
kman
IN
2000
can i make my 3.0 5 speed work with a 4.0 if so what will i need
No, it won't bolt up, the bellhousing is different.
ok is there a way i can hook my transfer case on to a two tranny
Huh?
You mean put a t-case on a 2WD trans?
Not unless you swap the extension housing and output shaft with those for a 4WD (requires a complete teardown of the transmission)
