3.0 taurus ECC will run an '87 2.9L
yodaman1151
Oregon City, OR
This came out of my 87 2.9L ranger. Long story short the little ground wire fell off the negative battery cable and killed the truck... I thought it was just the fuel pumps not turning on. Traced it to the ECC being the ground off the relay. So I though it was a bad ECC. Pulled it to find it was from the Taurus and put one in from a B2. I lost the hesitation problem at high rpm's I thought was a timing issue. Hopefully my gas mileage goes, way up 13 mpg is ridiculous
Probably the same pinout on both, or close enough to make it run.
So far it runs a lot smoother, has more power and does run like crap cold.... Exhaust doesn't smell as rich either. Definitely a different map ha ha
LOL I bought an 87 bronco II for a 4.0 swap, someone posted they needed a ecc for a manual 2.9 from an 87 dug out what I had pulled from the bronco and it was tagged a taurus, cant remember if it was a 3.0 or 3.8, guess it happens more than once.
That's weird.... Must be mapped the same but mine ran a little off and it looked like someone had been in there before cuz the little metal shield on the bottom corner was gone
