3.0 ranger with bronco ii tank
kevinskustoms123
1999 ford range
i got a 99 ranger with a 3.0 flex and so idiot run me up on a curb and busted the tank so i put the b2 tank in and used a 90 ranger sending unit and swap the pump and what i think is the regulator thats in the tank i thought i had it right but now it runs anywhere from 5 mins to 30 mins and then it cuts off. So if anyone has done this to a 99 ranger and got it to work please let me know what all you did to make it work with details please :icon_confused:
o the truck is bagged with raised bed floor on stargerd 19's
Are you sure that the pump is a high pressure in tank unit for the 99.
if the pump you used is a booster pump off a 2 pump system it won't have enough pressure.
