HowardJGifford
I recently bought a 2004 ranger edge 3.0 two wheel drive 5 speed with about 166k miles. The check engine light is always on. When first started, the engine runs good,,, ,,,(, usually). After a while the rpm's decrease and engine runs very rough and the check engine light blinks. After about 30 seconds, engine runs ok and check engine light stops blinking, but stays on. Runs good for about 23 seconds then faulters again. It seems to cycle. Runs good for 23 seconds then bad for 30 and so on. This happened while I was trying to maintain a constant 2k rp m. Seems the engine will start up in the same condition as when turned off.
I hope someone can help.
Thanks, Howard
Thanks, Howard
