SumoPsycho
- Dec 18, 2010
- Automatic
I want to replace the auto trans in my 2000 Ranger 4x4 with a 5spd.
I just bought a 5spd out of a 93 Ranger 4x4. I got the trans, flywheel, pressure plate w/clutch, clutch master cyl and slave cyl, starter and the peddle assemble for $85.00.
When I look at the interchange for the flywheel it says 95-08 is the same and the 86-94 is the same so I was thinking they must have changed how it was balanced. But when I look up the interchange for the harmonic balancer (crank pulley) it shows the interchange go's from 87-00.
Can someone confirm that I can use the 93 flywheel,clutch,pressure plate,master cyl and slave cyl in my 2000.
Thanks for any help with this.
