mixwell
For the past month now my overdrive light flashes and my transmission is very rough going into second gear. If I have the gas pedal down further it just goes up to red line almost and I have to let off the gas before it will switch. Once I get into 2nd it shifts alright from there on out.
If i punch the gas pedal then it seems to go into second gear. I tried a google search and couldn't find a solid answer but I've heard it could be something simple like electronic sensor and some have said their trans was toast. I checked the fluid levels and it looks fine. Any ideas/advice is appreciated.
Thanks in advance.
MixweLL
PS> I've read on another forum where someone replaced the speed sensor which resolved it so maybe I will try that unless someone else has had the same problem and an alternate solution..
Thanks in advance.
MixweLL
