84projectFORD
ok im kinda new to these engines but my friend has a 1999 ranger reg cab short bed with the 3.0 and an auto behind it. it will not start but cranks. if you push the throttle a little it backfires through the intake. no codes present. it is getting fuel (friend decided to replace the coil, coil pack, fuel pump, all the relays, fuel filter, Idle air control and MAF sensor before he called me) but it is getting spark and has fuel pressure along with the injectors working when cranking. i tried switching the crank sensor with his buddies ranger (same as his but an 01) and still no start. Is there a camshaft sensor that may have gone bad or soemthing else?? Im stuck and need help! lol. i have a scanner and all teh tools just never seen this before and unfortunatley the scanner shuts off when i crank it so i cant watch any senors to see if they are bad
