2WD vs. 4WD transmission
junkfixr
Virginia
I've gotten an 86 2WD running after sitting 6 mos. or more. On the first test drive the transmission wanted to hesitate in Drive and Reverse. After it warmed up, everything seemed to work fine - no more slipping.
The next day, same problem. Slips for the first 5 minutes when cold but moves and shifts fine after that. Haven't driven it more than a few miles yet but that can't be a good sign. Fluid is clean & full.
I have a 4 WD parts truck with the same trans. (A4LD) and was wondering if I could put it in the 2WD truck. Both have 2.9 engines & I'm wondering if it's possible with a little wrenching to swap the transmissions ? Transfer case adapter removed & the other tail bolted on ? Do they use the same output shafts but different tail housings ? What am I up against here ?
Any help or advice appreciated.
The major difference in the transmissions is the output shaft and tail housing. You would either need to swap over the output shaft and tail housing or find a dummy transfer case to stick on there.
I think I'd be changing the tranny filter. That's what they do when partially stopped up.
Big JIm
thanx a bunch...
definately wanted to try the filter first & put a few more miles on it before I go wrenchin'.
Good to know they will swap. That gives me a spare motor & trans, plus all the 4WD components. Thanx for all the help !
