2wd V8 ranger
Ranger850
Doesn't get Sarcasm . . .
Tallahassee Florida
Stock 2"
Stock
Doing things wrong, until I get it right.
I have a 2001 swb Ranger Edge with the 3.0 V6. I want to do a v8 swap but was wondering if there are other easy options for engines besides the V8 explorer. i.e. Crown Vic, Grand Marquis or LTC. I know I need explorer engine mounts but was wondering about wiring. Will the explorer wiring harness work with an alternative motor, or will the wiring harness and computer from the donor car work in the ranger. I haven't done or purchased anything yet, STILL DOING THE RESEARCH.
I think there's an issue with the motor mounts on the Explorer swap into a 2wd (coil sprung) 98+ Ranger.
This thread has some more details:
http://www.fordrangerforum.com/8-cylinder-tech/142923-motor-mount-97-v8-2000-a.html
2nd that ^
There is some cutting and welding involved with the coil ranger that I have read. I put my 5.0 in a 98 4.0 4x4 and only had to build a trans mount because I went with a f150 transfer case.
http://www.therangerstation.com/forums/showthread.php?t=174669
Take a look at my build to see if any info will be of help.
The OP has a 2WD Edge which is not a coil truck. The 5.0 Explorer engine mounts will bolt in without modification.
Thanks, I glossed right over the Edge reference. Good catch.
Sent from my SM-G930V using Tapatalk
Same here. I don't know how I missed the edge part. It pays off to have different eyes reading on the subject.
Thank you.
Thank you.
I even remember thinking 'if only he had an Edge, this wouldn't be a problem'. So much for reading comprehension...
Thanks everybody, and yes I have the torsion bars, no coils.
any body know where i can get a fully loaded Explorer w/5.0 V8? lol
Dont get discouraged they are out there it took me 5 months to find one around me luckily I found a 2000 wrecked Explorer with 54000 original miles on it
Tallahassee. we have a Pic-N-Pull here and there OK. But I know a dealer that can get me in the Auto-Auction. I'll probably go that route.
