lodden758
how hard is it to swap a 2wd bII to 4wd, and whats all got to be done. will I have to pull engine and swap the cross menber? It looks like it would be easy to do just want some extra input.
thanks
thanks
no....sorry, you are wrong....The whole front axle would have to be a custom job..IE SAS...The only vehicles the 2 to 4wd conversion is easy on is BIIs and pre 95 explorers...
As far as I know the drivers side beam bracket is the same for 2wd and 4wd b2s but you will need the 4x4 passenger beam bracket, someone correct me if I'm wrong.thanks for all the help, I'll be doing the swap tomarrow. one more quest whats the easiest way to get the drop brackets off, I don't have a torch. any sugestions?
thanks DJ
