There nothing different about the frames its just brackets that are attached to the frames that are different.
With everything I need to do the conversion plus a running 4.0L w/ 5spd its going to be a total cost of less then $600.
I got a 8.8 3.73 LS rearend from a 94 Explorer from a pull a part yard for $56, & rear leaf springs from same vehicle for $11 each side.
Front & rear driveline,U-bolts,blocks,rear sway bar,front & rear shocks,transfer case cross member & mount, transfer case skid plate,fuel tank skid plate all for $50 from a 94 4x4 off of Craigslist.
Im getting a D35 with 3.73 with all of the remaining 4wd brackets,4.0L w/5spd,all items in the engine compartment including a/c set up ,cruise control parts, Radiator & a/c condensor EVERYTHING in engine bay,plus all interior components including tilt wheel w/working cruise controls,both doors which have PW,PDL & PM for $400 which are in a 93 XLT from another person on Craigslist.
The engine has 132,000 on it but needs a water pump replaced.
The guy had a load of wood he was taking to his brothers & noticed the temp guage was getting warm ,so he pulled over & saw that the H2O pump was leaking, so he called his dad to pull him to his brothers house.
It sat there for about 6 months in a field near a small drop off when a drunk buddy of his brothers decided to ram the ranger with a 3/4 tn Chevy 4wd.
He rammed it about 4-6 times before it got pushed over the edge & went dwn about 15 ft & it was still on its tires, so the owner decided he's going to part it out.
A few weeks ago I went to a 4WD swap meet & got me a 1350 manual transfer case for $20 bucks that I offered the guy & a few days later saw a guy on C/L parting out the last year of Brc2 & he wanted $45 for a 1354 manual & I offered him $25,but he wouldnt go any lower then $30.
So you see its going to be a cheap conversion , cause i'll be doing all the work & I wont have to pay myself for my time.
I also have 86-92 comanche/cherokee finned alloy wheels that I got from 4Wd swap meet 4-5 yrs ago that had 235 GY wrangler radials on them for $40 for the set & in Dec.07 I got a set of barely used 31x10.50/15LT Yokahoma Geolander A/T tires that was on a rolled Nissan truck from a bone yard for $150, these tire didnt even have 1800 miles on them.
Now im not counting the cost of these tire & wheels being that I had already had these prior to me deciding to take on a 2wd -4wd conversion.
Between C/L, Pull-a-part yards & general bone yards & me making offers I have done very well.
I also got a 31x10.50 /15 GY Wrangler MT mounted on a nice alloy wheel for a spare with about 40% of tread left for $20 & a few yrs old never installed/unused Warn Transformer brush /grill guard for $65, fiberglass 7ft canopy with tinted windows, carpeted inside /w int. light,cab high in front & raised ceiling near back whick was 4 yrs old & still in great shape ,but wrong color for $100 & flip style stainless steel bed extender with hardware for $20 & a unused Delta hard plastic cross over bed tool box for $20 that a guy was given with a canopy purchase. This tool box is a bit narrower then the steel or aluminum ones & the gull wing lids can be un bolted & will be able to sit inside my canopy & also a 6000lb 2" receiver hitch for $40. All of these last few items was from C/L also.
So as you can see I do hunt around & make offers to better my spending.
WILL: you might be a truck whore ,but theres much more pride in a vehicle you build then in one you buy.
Trust me I have had several projects in my past & currently have a few now as well as this 4wd conversion
