henryj10
2wd front leveling Axle-beam Bolts
The tech library is vague in this area says you can add longer bolt to level. I was wondering what if any, are the results. Can I add a longer bolt, will a bolt 2"'s longer level my front end or is the purpose of adding of longer bolts only so your able to add taller spacers?
I'm trying to level my front end on my 96 4cyl 2wd abut 2" and I am not completely sold on the spacer idea doesn't seem durable and the longer coil spring doesn't seem like it will last and just sag with time.
All around whats the best most durable way to level the front end and whats the less costly fast simple way to level the front end about 2".
Lastly what are the limits of leveling to where you cannot get the vehicle re-aligned. I've heard there is a point where the settings for re-alignment are impossible to get back?
Thanks
Jason
Thanks
Jason
