2wd EDGE front brake rotor size? 11.25 or 12
NicoNO82
Alright I am in the middle of a lot of confusion that could be solved with a tape measure most likely.
Basically, I need to replace the front brakes on my truck.
However last time I did it I had a problem when I purchased the new rotors. I bought rotors that were too small. Easily swapped them out but now for the life of me I can not remember what size the correct ones were.
I am looking into ordering them online but I see two size options for rangers11.25" and 12". I know for sure the 12's are for the 4x4 models and I know older rangers used the 10.whatevers, but do the 2wd Edge rangers use the 12" rotors or the standard 11.25"?
I pulled the wheel today to measure but, giving the calipers being on and the bolts and such sticking out, it is dificult to get the correct measurement without removing the rotors. Pulling the rotors is out of the question until I am ready to replace them.
well i answered my own question today.
11.25"
Difficult to measure with all the shit mounted, used two framing squares.
