Brain75
- Aug 8, 2024
- ~Sterling, Colorado
- 2.9 V6
- Tire Size
- 215/70R14
Before a 2 month coma to paint it, I know the washer worked fine and think the wipers worked (note: I only tested them by flipping on and off - might not have been a good test).
After painting and putting all the front body back together the washer pump does not spray and the wipers only work on high, no worky on low or intermittent at all.
Sidenote, the only stuff I have done under the hood is unbolt the grill/lights etc - front trim components that had to come off for paint.
The washer pump made the sound of running for a second and I realized I got some buffing compound in the nozzle so I stopped and cleaned it up with a pick and solvent /water.
I figured the multifunction switch was dying (hence intermittent and low), and that the motors were both good... well "new" column, "new" multifunction switch (junkyard) and the behavior is still the same. But the washer pump quit making any noise.
Read through Haynes (very little to nothing- just how to remove the washer pump) and read through Chiltons kinda the same with the remove/replace of the wiper motor. Neither had any troubleshooting or where to look...
A search here on TRS yielded all 3rd gen stuff involving 2 relays and the GEM - I have a 2nd gen, no GEM... and nothing in haynes or chilton say where these relays would be... fuse boxes is all circuit breakers and fuses no relays in 2nd gen electrical boxes.
Since the wipers move on high, I assume the motor/linkage/etc are good, since 2 multifunction switches have the exact same behavior I assume it is not a problem in either switch. Where do I go from here? Is there a pair of relays hidden somewhere I'm not finding just in the harness somewhere?
