66 Ranchero
i have an 04 FX4 and i was curious if the rear axles were 29 spline or 31 spline
Let me think about that - five mins to crawl under and measure it, no cost.pull your axle, count the splines....
I believe you would have the 28 spline axle. The tech library has this to say:
4) The FX4 Ranger was introduced in 2002 and always came with 4.10 gears only. The 31-spline Torsen 8.8-inch axle came only with the 2002 FX4 and 2003-up FX4 Level II and more recently was a separate option. The 2003-up FX4 (non-Level II) is essentially the same as the 1998-2002 Off-Road except that a regular Ford limited-slip in a regular 8.8-inch was included."
I forget what the diameter of the axle tubes are, maybe the 28 is around 2.75 and the 31 spline is like 3.25. Easy way to tell if you know the tube size, I just can't remember right now.
Dave of the Nord
Pull an axle -maybe an hour, couple qts of gear oil. Kind of a tough call!
Dave of the Nord
Didn't the 28 spline use the same axle shafts as a 7.5 too?
That would really open up options for the OP...
ford some reason i think the shaft size is different, though i could be wrong. i thought i read somewhere it was, one of the reasons i avoided a 7.5 when i was looking.
