97LowRanger
Hey guys i need some help i just bought two 16x8 cragar D window rims with 5" backspacing 0 offset, it has about 3.5" from the rim lip to the leaf spring if needed i might use spacers the question in can i run 255/50R16? i want to keep the speedometer the same that seems to do it according to tire calculators, for the front i dont want to go as wide i will buy 16x7 4" backspace 0 offset, i was thinking on running 235's but it could rub as the toe is off right now and 225 rubs a little so i was thinking on keeping 225 and use something like a 225/60R16 again to keep them the same overall size as stock ordo front tires affect speedometer reading? i know the sensor is in the diff but will it affect the over all vehicle speed? and does this set up sound ok? will the tire sizes work? any help is appreciated!
Forgot to mention its 2wd single cab lowered 3/4
