- Sep 21, 2007
- Wa, Bremerton 98310
- Total Lift
- Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
- Total Drop
- Ranger 5sp, BII A4LD
- Tire Size
- Ranger 32"/4:10LS, BII 33"/3:73LS
- My credo
- Deengineer until it is how Blue Oval should have sold it!!
Eric:
I covered all the bases to have the donor be reliable; timing chain, water pump, oil pump, push rods. I am getting ready to inspect the lifters as a new set is not currently in the budget. I was concidering slipping in SOHC Pistons with new rings but the looming PCM choice has me twisted.
I thought that I would just grab a 94 non-EGR comp/harness and be done with it. Turns out where I live that's rarity in the yard.
So I brought this issue to the boards, the responses I received were all over and didn't help me make a decision. The one that stuck out in my head was to use a 98 setup to capitalize on the newer tech for better performance.
Adding to this, since I can't manually advance the timing I am left with either a piggyback power module on a 90-94 or tuning on the Dyno for the newer systems.
I was able to get away with a lot on the old 87 computers, more than I needed but I don't know how much these new systems will permit.
The only OB² I have messed with, I only did a cold air, cat-back and hot ignition. It worked very well but I am less certain about this
So my delima is, I would like to do this once and have it run well; I am willing to CHiP it or tune to get the timing it will need.
Initially it didn't seem reasonable to consider using a newer computer/harness but now I wonder if it would work better?
