ok first off run a ground wire to your main panel to pick up your sub panel so you DON'T get a ground loop thats dangerous and can make weird things happen 2. NEVER use rebar as a ground rod because it WILL corrode and you don't want your rebar thats holding your house together to corrode.
....you make it sound like grounding the rebar will make it corrode? In the 4 years i have been doing electrical i have NEVER had to replace a ground connection to a rebar. In a detached building or a garage even built onto a manufactured home or what not they make the builder stub up a rebar for the ground and in some cases they make you use the rebar for a ground. I have never seen a rebar thats being used for a ground corrode...its a really good ground. By the way if you are running wire in a conduit from your main panel to your garage and its detached...or even if it is attached you have to run a 4 wire to your panel...which has a ground in it.
