208 transfor case
okietheranger
santa rosa
does anyone use the NP208 transfor case? when i was puttin up the tranny with the transfor case on it seams like its a little bit to close to the driver side fram? would this case work or do i need the NP205? thanks your all your help!
If you go with a 205 you will need to make a mount just for the case because it is so heavey it will break the tailshft off the trans without one.
dang i already have the 208 but ill try to find 205 thanks for ur help
