2011 Ranger XLT Rear Diff Play
Yep, 2010 and 2011 were the only years to get rear disc brakes from the fatory. Usually, the auto parts places get that right. Weird that you are having trouble.
If the carrier is cracked, that definitely needs replaced as soon as possible. Since there are vaiances in carriers, expect to need a shim kit to get the back lash and tooth engagement set right again. Ford axles are a real pain in the butt to setup. So expect a lot of installing and removing the carrier. You might get lucky and the new carrier will take the old shim setup, but don't hold your breath
Since you don't have to mess with the pinion, that will male things easier. You just need to worry about the side to side distance in getting the tooth engagement right.
There is an article or two in the tech section that will show you what it should look like.
I did have some issues with ordering brake pads the first time when I first got the truck but maybe that was just amazon's fitment and/or my own ignorance at the time idk. But I haven't had any issues since. So it's not actually the carrier itself that is cracked, it's just the cage for one of the carrier bearings. It still seems functionally okay but I know that's no good. I almost wonder if that's from when it was installed and they just decided "oh well" and rolled with it. It was cheaper to order the bearing kit that comes with carrier and pinion bearings, a pinion seal, crush sleeve, gear paint, diff cover gasket, etc but I just plan to only replace the carrier bearings and use the pinion seal and diff cover gasket. I'll hold onto the pinion bearings and crush sleeve for the future when it comes to it.
The only shim I found was behind the right side spider gear so I'm hoping the replacement gears and bearings for the carrier match and kind of put everything back into alignment using that same shim or maybe I won't even need that shim with non-worn spider gears. I will check it carefully though and order some shims if I have to before closing it all up and running it.
Sounds like you have handle on it.
Thanks for your help Senor.
  • 2011 Ranger XLT Rear Diff Play
Agreed. It should be pretty obvious if it's dragging. Sounds like OP already has parts on the way. Might as well use them.
Yeah, it seemed functionally fine. I bet it's been there since installation. But I already got the bearing separator yesterday and the replacement bearings should be here in a couple of days so I'll just use the parts and get the practice in.
the gears on the shaft ends are called side gears. there should be a flat spacer/washer/shim between each side gear and the housing.
they are actually just precision washers, don't do any adjusting of clearances.
the smaller gears on the pin are the spider gears. each should have a cupped washer.
the spline wear on the axle shafts is weird, part looks good, other part is badly worn.
what do the internal splines in the side gears look like?
do they easily slide on both shafts? swap them for test fitting.
is the entire housing straight? visually sight it end to end. if you can rig up disks with small holes that works fine.
friendly reminder:
spider and side gears only rotate against each other when there is a difference in wheel speeds, like going around corners, curves, or doing 1 wheel spins.
99% of the time you're going in a straight line, those gears are not turning against each other. or the diff pin.
even going around a corner there is only about 1 rotation of those gears. just enough to make up the difference the outer wheel turns.
friendly reminder:
Thanks for the clarifications. I won't forget. There was only one flat spacer/washer/shim total and it was between the right side gear and carrier housing. I'll say yes they easily slide on both shafts and I can't visually see any wear or uneven wear on the inside grooves of the side gears. They look to be pretty solid. There is play between them side gears and the splines of the axle shafts no matter which way I combine them but it's not too bad. So I think that means though the axle shaft splines are definitely worn.
As for the actual spider gear wear, maybe doing this on low gear oil doesn't help. Oh well. Here we are. Lessons learned.
Well it turns out that "clunking" noise had nothing at all to do with all the slop in any of the gears. It was actually so easy to identify the noise that it's kind of embarrassing. It's the head of the studs in the wheel axle hitting the parking brake lever/actuator on the passenger side because the actual shoe itself came out of place. Not sure how or why it did yet but I guess I got so married to the idea that it was coming from inside the rear diff that I didn't even really try to isolate it further. And I only drove any of the gears manually by hand from the pinion itself or the driver side axle so it always kind of just sounded like it was from the middle of the rear. I threw in the new side gears, spider gears, and crosspin shaft to see the difference in slop and spun the gears from the passenger side axle this time and the source of the noise was so obvious immediately. If I push the parking brake shoe in, it gives the clearance between the parking brake lever thing and the stud heads and the clunking completely goes away. All the hardware for the parking brake shoes is rusted to hell though so I bought new shoes and am waiting for the hardware kit still. Backplate is good. Overall though, I'm still glad I bought the spider gear kit because the difference in slop inside the rear is night and day. Even with how worn the axle splines appear, there is noticeably less play with the axles and new side gears so I guess the inside of the old side gears were more worn than they appeared to be or the machining is different with these new side gears. And then inside the carrier with it all together, so much less slop between the spider and side gears. Huge difference. Very happy with it. Ready to get this damn thing back together though so I have a vehicle.
Vid:
If it still opened up, and you're willing to take a small amount of risk, you can make the diff act like a limited slip by adding one or more shims to the side gears. I've done that to a 9" and a d-28. It doesn't last forever and there is a chance of grenading the rear.
She was still opened up at the time but I chose to just play it safe for now. Thanks for the tip though.
So it turns out the extreme clunking that developed which ended up being the parking brake hardware hitting the axle shaft stud heads is fixed but I still have the original tinny sounding clanking noise. I ended up jacking up the rear with front chocked and ran her in drive and the rear is dead silent and smooth. I was under the impression it was the same issue but just got worse. Nope, unrelated. Got it all on jack stands now and it's clear as day the CV joint for the front drive shaft. It's shot bad and rattling around. It's nice having a garage to work in now. Been living in apartments since 22' where they would complain about everything so I was kind of handcuffed. Just moved into a house last month over July 4th weekend. Moved everything alone with just my little rusty Ranger. Loaded her to the brim. What a breath of fresh air having a garage. Excited to get to start attacking some of these things. A lot of leaking seals I'm seeing...
Front drive shaft CV joint rattle
Pulled for now. Should get part tomorrow.
Just to finish the story, I got the CV joint repair kit which worked out great. It was much cheaper than replacing the entire shaft that came with a new CV joint and u-joint and the job was easy with the right tools which I bought to save time and I know I'll 100% use again. I also replaced the u-joint while I had it out. It's been installed for several days now and that clunking is completely gone. It's so quiet driving now with just a little bit of exhaust noise. The piece of mind. Ahhhhhhh. I'm so happy with the results. So, two totally unrelated clunks have been fixed and I learned a lot in the process about the rear end as well. I also have an actual working parking brake now on top of a much improved tool set as part of the process. I decided to cancel the return for the rear end bearing kit as well as some shims I bought just in case. I'll keep them just cause. Up next is the intermittent 4x4 before winter hits and then probably the other leaky seals, nasty looking CV joints, etc. Oh, and turns out the front drive shaft CV joint was also responsible for like 90% of the squeaking I had. Thanks for all the info and help everyone. Much appreciated.
The intermittent 4X4 is usually the shift motor or something wrong with the wiring to the motor.
One thing we have learned is that the truck needs to be put into 4 high and 4 low every so often to keep the contacts in the motor clean. Once a month seems to work for me, though I do try to remember to do it more often.
It is possible the the contacts just need cleaned in yours, but that would be too easy, cheap, and simple. Hope for the best but plan for the worst.
I think you're spot on. When I first bought the truck, it worked. Few months later when I needed it, it didn't. No lights on the dash, no sound from the motor or transfer case, zero activity. From some reading, I was convinced it was the transfer case control module so I bought that and it still didn't work. Replaced the motor and it worked but I also bench tested the OEM motor with my bench power supply and it worked both directions every time when applying a voltage and reversing polarity. Then, shortly after it stopped working again with the new motor. If I remember correctly, I think I tested again with the new motor unmounted but harness connected and I could hear the motor running from inside the cab. And then it kept working when I mounted it and so I kept trying to engage it like once a month but it eventually just stopped again. I sold that transfer case control module at a discount on ebay. This last winter, once I got it to engage once, I kept doing so multiple times a day and it seemed to eventually engage at least after driving for an extended period of time. Worked through the winter like that but now we're back to before. Even after a long drive, zero activity when trying the 4x4 controls. So I think for my particular case, likely a wiring issue. I probably need to inspect the harness closely, check my grounds, maybe probe the harness, etc. I'm confident I'll get it this time around.
Featured Ranger Based Vehicle
