2007 Red Trailer 4X8 Utility Trailer
I'm back to work on the trailer. The modified hinge pieces that mounted the ramp section to the frame were removed as well the brackets that hold the middle section support legs when they are not in use. The rear section of the trailer is back on it's stabilizing jacks and wooden blocks to remove the frame sag. So, hopefully I can get the frame and angle marked for hole positions in the next few days. I do need to put a 45 degree cut on the down leg and an angle cut on the side leg to match the angle of the tongue supporting braces first so I can make accurate marks on the angle iron. Then it's lots of drilling.
I'm back to work on the trailer. The modified hinge pieces that the ramp section were removed as well the brackets that hold the middle section support legs when they are not in use. The rear section of the trailer is back on it's stabilizing jacks and wooden blocks to remove the frame sag. So, hopefully I can get the frame and angle marked for hole positions in the next few days. I do need to put a 45 degree cut on the down leg and an angle cut on the side leg to match the angle of the tongue supporting braces first so I can make accurate marks on the angle iron. Then it's lots of drilling.
If you need some welding, I got the wire feed working good and the Choptop getting better fuel economy so we can talk.
There will be for the tray itself. I haven't gotten the steel for that yet. Flat strap that will be the cross bars will need to be welded to the angle iron that will make up the sides of the tray that will get bolted to the angle iron I currently have that is for the frame reinforcement.
I was able to get some more work done today. Mostly measurements and markings under the trailer but I did cut the front of the angle so it will fit in the front c channels that brace the trailer tongue.
More work got done on the trailer. The rails are installed. I still need to fabricate the c shaped pieces out of 4" X 4" X 3/16" flat bar. They will sandwich the front and rear pieces of angle iron around the 2" X 2" cross bar for the suspension, linking the two together. One with the opening facing aft and the other with the opening forward. Along with some angle and flat bar filling the gaps on the top and bottom, that should provide a strong enough link between the two. That will be almost 5/8" of material all bolted together wrapping around a 2" X 2" X 3/4" square tube.
More progress was made on the trailer. I got pretty much everything done to link the front and rear sections of the angle iron on the left side. I still need to make a gap filler for the bottom side but everything has been fabricated for the sides and top. The metal pieces on the side are just filler pieces to make it so I could drill out the filler angle section on the top.
Looks complicated...
