sgtsandman
Automotive Technician
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
I'm back to work on the trailer. The modified hinge pieces that mounted the ramp section to the frame were removed as well the brackets that hold the middle section support legs when they are not in use. The rear section of the trailer is back on it's stabilizing jacks and wooden blocks to remove the frame sag. So, hopefully I can get the frame and angle marked for hole positions in the next few days. I do need to put a 45 degree cut on the down leg and an angle cut on the side leg to match the angle of the tongue supporting braces first so I can make accurate marks on the angle iron. Then it's lots of drilling.
