2007 Red Trailer 4X8 Utility Trailer
I'm back to work on the trailer. The modified hinge pieces that mounted the ramp section to the frame were removed as well the brackets that hold the middle section support legs when they are not in use. The rear section of the trailer is back on it's stabilizing jacks and wooden blocks to remove the frame sag. So, hopefully I can get the frame and angle marked for hole positions in the next few days. I do need to put a 45 degree cut on the down leg and an angle cut on the side leg to match the angle of the tongue supporting braces first so I can make accurate marks on the angle iron. Then it's lots of drilling.
I'm back to work on the trailer. The modified hinge pieces that the ramp section were removed as well the brackets that hold the middle section support legs when they are not in use. The rear section of the trailer is back on it's stabilizing jacks and wooden blocks to remove the frame sag. So, hopefully I can get the frame and angle marked for hole positions in the next few days. I do need to put a 45 degree cut on the down leg and an angle cut on the side leg to match the angle of the tongue supporting braces first so I can make accurate marks on the angle iron. Then it's lots of drilling.
If you need some welding, I got the wire feed working good and the Choptop getting better fuel economy so we can talk.
There will be for the tray itself. I haven't gotten the steel for that yet. Flat strap that will be the cross bars will need to be welded to the angle iron that will make up the sides of the tray that will get bolted to the angle iron I currently have that is for the frame reinforcement.
