2007 Ranger lowering?
Not unless you want to replace the suspension with a coil-over setup... as it is, if you lower your suspension with unscrewing the T bars your suspension will get REALLY soft. as it gets really stiff when you crank it up. I would fully expect you to bottom out often if you do the drop with the t bars. not to diswade you but just giving warning.
