2004 Ranger - Lower Control Arm Crossmember Rotted - Replacement Options?
punk
Massachusetts
I picked up a 2004 Ranger Edge in early December for a good price and just recently found the lower control arm crossmember is pretty badly rotted and I'm trying to get an idea of what replacement options I have.
I went to a local frame repair shop and was quoted ~$1,800 to have it replaced with a whole crossmember from another truck (but he's having a hard time locating one in decent condition). Is there any aftermarket replacements available or is it possible to order this part new (doubtful as it's welded to the rest of the frame).
Here is a [pretty bad] picture of the carnage:
https://i.imgur.com/ckt3CNf.jpg
I know it's a bit difficult to see where that is, so I circled it on picture I found on Google. The part I have circled is the front side, the rot on my truck is on the back side of that crossmember in the circled area.
https://i.imgur.com/zbIvz6d.jpg
Any thoughts or ideas would be helpful.
How mechanically inclined are you? I think I would buy a rollover and swap bodies. Or part it out and use the money for another truck. It looks like you were sold bad goods, you may have recourse if it was knowingly sold that way, especially if it was a dealer.
That sucks.
Good luck,
Richard
That sucks.
Good luck,
Richard
Thanks, I'm mechanically inclined enough along with my family so a swap like that wouldn't be a big concern. I was just hoping there was a more "off the shelf" type of replacement that was available. I've searched around but haven't been able to find anything really and figured I would ask on some forums as I'm sure you guys are far more familiar with the trucks and parts availability.
I'm not really interested in recourse as I definitely should have looked it over better myself. Everything I could see from bending/kneeling down on the wet/muddy ground in December looked fine; it wasn't until I was under there to replace an endlink that I noticed it. The truck was almost an impulse buy as I needed another vehicle to drive daily while my car was getting a rebuild; the price was right and it appeared in good condition. Guess I learned my lesson there :black_eye:
I can't say there isn't oem or other replacement parts made. Perhaps check Dorman, they seem to have lots of stuff. It's getting the correct name to do the search that may be hard.
This is exactly what I was looking for; never came across Dorman in my searches. I have OEM part numbers for the frame so I can start there.
Thanks!
I seen ads In MA Craigslist. There is a guy selling 98 and up frames in Weare, MA. Good luck.
Try lmc truck they have all kinds of goodies but as far as finding one id go with the post above find one thats smashed in the rear and cut off and replace
O and dont forget the SAS option [emoji3]
SAS? Sorry, I'm from a different car world so if that's a truck or TRS forum thing I have no idea what it is :dntknw: I'll check out lmc truck as well, thanks!
Thanks, Andy, I'll take a look around on CL.
SAS = solid axle swap drop in a dana 30 jeep lots of build threads on here
