2003 Explorer cranks but won't start
Shellz
Explorer won't start periodically for the last 2 years. Fuel pump is fine. Usually after some time, it will eventually start. A couple of weeks ago, it stopped running in the middle of driving and hasn't started since. A few times, it sounds like it wants to turn over, but then doesn't. It has the 4.0L V6 engine.
Thanks!
Do you have fuel pressure? IIRC that year had those stupid fuel pump driver modules mounted to the frame and those get rotted out bad.
You could also have an ignition control issue.
