2002 3.0L rough idle
Kenny Stanley
5+ Year Member
El Cajon CA
I purchased a 02 ranger 3.0L motor runs great just has a rough idle 210,000 miles on the clock ,has new coil , wires, just replaced fuel filter not sure why it idles like this ?
Check for vacuum leaks and egr bleed over
Sent from my SAMSUNG-SM-G870A using Tapatalk
2002 Ranger
Ok I looked for vacuum leaks with a smoke test found nothing , still has a rough idle and now it seems like when you are down below 2500 rpm that it surges, I have replaced cam synchronizer according the the thread on this site still at a loss here . truck runs great about 3000 rpm
All the Ranger 3.slow's idle a tad rough. Inherent.
It's time for a compression test.
You get used to it and don't realize it but they all do just a tad. Doesn't mean anything is wrong. If it's shaking the cab, that's a rough idle to be concerned with.
Figured it out the cat where plugged up gutted them runs like a champ . Yes it does have the little rough idle still taking it as nature of the beast :headbang:
