20011 escape key problem
alwaysFlOoReD
Airdrie, Alberta, Canada
'06, '11
The ignition key switch at the top of the column is loose. I have to wiggle the key to get it started. Its getting worse. I'm afraid that soon no amount of wiggling will help. I was thinking replace the switch but I dont know about pats. Is this something I can do myself or is it a dealer item?
Thanks...
from my experience as a ford parts guy(10+ years) you need what is called the steering column lock module. The fact that you have to wiggle the key is a dead giveaway that it is failing
PN 9L8Z-3511-A IIRC . there is also a shear bolt that needs replaced as well
If you replace the cylinder with one that matches your keys, nothing should have to be changed with PATS.
If you change keys, you’ll need Forscan or a pro grade scan tool that can get into the anti theft system.
I haven’t checked for awhile, but there was a guy on eBay awhile back (Wolf Security) who would pin out new automotive locks to work with your keys. Most locksmiths can do it as well and of course Ford should be able to get you a matching cylinder.
Check with you local locksmith. They may be able to help you with this. Should be cheaper than the dealer.
Usually is. I mentioned buying off the guy on eBay because he was half the cost of the local locksmith who was half the cost of the dealer when I needed some stuff back before I started dabbling in locksmithing.
So I looked on rockauto and found these;
One is less than half the price than the other, but doesnt show instructions included. Is this what I need? I'm going to stop by the local dealer and see what they have also.
I want to try pinning this myself, is it possible?
View attachment 137146View attachment 137147
It’s just a wafer lock, little fiddly with the tiny springs but pretty simple to do, you just have to find the right wafers to use to match your keys.
I stopped in at the ford dealer. $139 + tax, order monday, in on Tuesday. Ordered it from Rockauto for $67 tonight (Friday), delivery Tuesday.
Ive had the same issue, I thought it was the switch itself, the 2011 was worse than the 2009. On both you had to push and turn for it to turn over. bought both a new switch, the 09 has been fine since, the 11 was better for a couple of months but went back to how it was before. Always does start but makes you wonder. Just want to convert it to a toggle switch & push button! My daughter has it now, not sure when I will get it back. Must still be working, Im sure she will let me know when it doesn’t.
Never done wafer style, but I keyed new door cylinders to my ignition key. Definitely fiddly, but I didn't have any extra pins. Just the worn out ones from the old lock and the new ones. I ended up filing some of the longer ones down to fit. And leaving one pin out of each side. That should mess with somebody trying to pick it. LOL
I wish ford did that, when you order a cylinder you get bag of tumblers and the cylinder housing
That's so you can key the new lock to match your existing keys. Before they did that a new lock cylinder meant you had to change all the locks or carry an extra key.
