- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
I goofed and deleted the thread, sorry.
I was able to go back and copy it but can't restore it myself. I'll see if someone higher up can help.
unfortunately, the original post is gone forever.
Here is what I was able to copy;
Default 2.3 2001 what engine will fit?
ok,
so i´m sitting here in germany and my ranger died beyond recovery, need to put another engine which is really hard since these cars have never officially been sold here so its almost impossible to find parts...
however, i really want to keep it and will do anything to get it back on the road.
i need to replace the engine since the block has been destroyed beyond repair. i don´t want to swap for diesel or 6cyl, just keep my 2.3 4cl.
which other years will fit? what do i have to look for? up to which year?
this is my car:
Car VIN: 1FTYR10D91TA88306
Manufactured Year: 2001
Make of Vehicle: Ford
Car Model: Ranger
Auto Style: REGULAR CAB PICKUP 2-DR
Car Engine: 2.3L L4 SOHC 8V
Production Country: UNITED STATES
Vehicle Trim: XL 2.3 2WD
Sequence Number of Production: A88306
Car Gearbox: 4-Speed Automatic
for example, would this be a replacement that fits?
2008 Ford Truck-Ranger 93K Miles Engine 2.3L (VIN D, 8th digit, 4-140)
https://www.ebay.de/itm/2008-Ford-Tr...oAAOSwIC1Z3B2R
Thank you very much!
Michael
von_sieben is offline Add to von_sieben's Reputation Add Infraction for von_sieben Report Post IP Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 06:32 AM #3
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Feedback Score: 14 reviews, 100%
Send a message via AIM to adsm08
Default
Yes, that example engine would fit. Any US Ranger 4-cylinder form 2001.5 on up would work. Some of the globally sold ones, which were very different, had 2.3L engines that are not the same.
Also any Ford product that had the engine code (8th digit of the VIN for US VINs) as D will have the same engine. I don't know how that might change on international vehicles.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
When people ask me "what's wrong with you?" I ask them "where would you like me to start?"
Quote:
Originally Posted by Thomas Sowell
If you are not prepared to use force to defend civilization then be prepared to accept barabrism.
Shop manuals
adsm08 is offline Add to adsm08's Reputation Add Infraction for adsm08 Report Post IP Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 09:04 AM #4
von_sieben
Vehicle Year: 2001
Vehicle Make: Ford
von_sieben is on a distinguished road
Feedback Score: 0 reviews
Default
Thank you, helps a lot. It´s almost impossible to find information or parts over here.
how long have these engines been build, or, up to which year should i look?
than you!
Old Today, 10:58 AM #5
tomw
Vehicle Year: 1985
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: for everything
My credo: vertical and above ground
tomw has a spectacular aura abouttomw has a spectacular aura abouttomw has a spectacular aura about
Default
The 2.3 is a Mazda design, and the "D" code listed on the German site should be a bolt-in replacement. You could find a 2.3 in a Mazda '3', I think, that would need to have the head gasket changed(coolant routing may be different as it is FWD, Ranger, RWD.), along with the accessories.
tom
tomw is offline Add to tomw's Reputation Add Infraction for tomw Report Post IP Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 12:16 PM #6
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
The only drop-in engine was in the Rangers between 2001.5 and 2011.
__________________
Shop manuals
Old Today, 08:06 PM #7
pjtoledo
Premium Member
Vehicle Year: 2000 2005 199
Vehicle Make: Fords
Vehicle Model: Rangers Taurus SHO 5spd
I use this vehicle for: going to Cabelas
My credo: get outta my way, I'm falling!
pjtoledo will become famous soon enoughpjtoledo will become famous soon enough
Default
you have conflicting information in your car description.
2.3L L4 SOHC 8V is the older "lima" style engine used up to about 1998.
the newer Duratec engine should be 2.3L L4 DOHC 16V. it began use in mid year 2001, continued thru 2011.
the 8th digit in your VIN is D, that should be the Duratec engine.
any Mazada B2300 pickups in Europe? they are the same truck.
the intake manifold is slightly different between a 2001 and 2008. the 2001 has a diverter flapper mechanism, the 2008 will not have it.
pjtoledo is online now Add to pjtoledo's Reputation Add Infraction for pjtoledo Report Post IP Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old Today, 08:15 PM #8
pjtoledo
Premium Member
Vehicle Make: Fords
Default
Quote:
Originally Posted by von_sieben View Post
ok,
this is my car:
Car Model: Ranger
Michael
you should have the 2.3L L4 DOHC 16V,,,, correct?
