Bill WV
- Nov 29, 2014
- Automatic
I have a 2000 Ranger XLT 4wd, 4L v6, auto. 240k miles, but the problem has existed a long time- just worse now. Starts fine cold but if it runs a short time and is turned off, won't restart. Cranks fine. I replaced the IAC solenoid since I had problems with that in the past. Swapped the fuel pump relay. When it does start, it runs fine. If it is fully warmed up, starts fine. I am going to check the fuel pump pressure, and I am going to clear codes to reset the check engine light then see what new ones come up. I was in Cleveland yesterday, at 25 degrees, it would not restart even after 3 hours. When it finally did start, it really ran rough for a few seconds then it was ok. I drove home to WV w/o turning it off for 6 hours, ran fine. Any other suggestions? Thanks- Bill
