parashootist
I have the trans off of my ranger to change out the clutch since there was a squealing noise. Turned out the pilot bearing had disintegrated. While under the truck I noticed the oil pan gasket was pushed out in the front under the harmonic balancer and what I thought/hoped was a rear main seal leak was the oil pan leaking around the crankshaft in the back. I don't have an engine hoist so I'm not sure of the best course of action. I hadn't noticed any oil leaking to the ground from the truck but since I have the trans off, I'd like to address this issue.
Is it worth trying to loosen the bolts, push the gasket back in at the front and maybe add a bead of silicone gasket maker at each end? I'd like to avoid having to lift the engine.
Truck has 183k. I bought it in the fall for $500 since it was not driveable. Installed a clutch master cylinder in front of the seller's house and drove it home. I have put 1000 miles on it since then until the clutch started acting up due to the pilot bearing.
Separate issues, also noticed some play in the input shaft but inspection of the internals, everything looks brand new so I will likely leave the trans alone. Installing new flywheel, slave, clutch, and pilot bearing. I was able to get the trans out with the Y pipe in place but I have little faith I will be able to reinstall it unless I remove it. I was unable to remove 2 of the bolts on the passenger side that connect to the manifold. Considering cutting the bolts, just not sure of the best way to extract the remainder once cut.
Thanks, sorry there's a lot there, any help is appreciated!
