mattging94
So the first thing I need advice on is some ignition stuff. I'm getting codes 223 and 224, which suggest either the coil packs or ignition control module are bad. So far both coil packs and the ICM have come up as ok. I'm still suspicious of the ICM, but I don't want to just start buying parts until I know for sure whats tripping the codes. Anybody have advice you can give me on where to go from here? I can take it to the AAMCO where I had the codes scanned and they can work on it for $90 an hour, which is more than I want to spend, but at the same time I'm starting to think that this issue is beyond what I'm comfortable working on.
The second thing I need advice on is my catalytic converter. I just realized it's leaking right out the bottom of the heat shield. It sounds kinda crappy where the leak is, so I'd like to either replace the cat or delete it all together. Thing is, while just deleteing the cat will be way cheaper and easier, I'm gonna be spending six months in the Sacramento area in the future, and I don't want to get ticketed for busting California smog-laws. So does anybody know if they check emissions in the Sacramento area a lot, and if I would even be subject to them living there temporarily? How much are the fines for breaking emissions in California any ways? What are the odds I'd get caught running without a cat around Sacramento?
