2 piece Dana 35 ujoint and ds support bearing sanity check
jballard81
Terminal Procrastinater
North Carolina
After an embarrassingly long amount of time reading and rereading the service manual, I'm pretty sure I found the correct replacement ujoints and driveshaft support bearing, but would appreciate confirmation before i place my order. going on a 94 ranger 4x4, 8.8 rear axle.
so the driveshaft support bearing has a spicer replacement option: DANA 2115901X
earing Id (IN) A1.181
Bracket Width (IN) C1.310
C-L To C-L (IN) D5.880
Cl To Mounting (IN) B1.940
Series1310
Style11
This one appears to be greaseable. not sure if that is preferred or not. i would imagine so...
then i would need 3 ujoints: DANA 513101X
Bearing Cap Diameter (1) (IN)1.062
Bearing Cap Diameter (2) (IN)1.062
Bearing Cap Diameter A (MM)1.062
Bearing Cap Diameter B (MM)1.062
Bearing Cap FinishGround
Bearing Cap TypeRound
Bearing Cap Type AOSR
Bearing Cap Type BOSR
Coating TypeNone
Grease Fitting LocationOne lube fitting in bearing
Grease TypeN.L.G.I. Grade 2
Grease Zerk IncludedYes
GreaseableYes
Hardware IncludedNo
Length A (IN)3.219
Length A (MM)81.8
Length B (IN)3.219
Length B (MM)81.8
MaterialSteel
Model NumberSPICER 1310/SPL22
OEM MfgSPICER
OEM Series1310/SPL22
thanks in advance!
sorry there are no responses , for us both.
I have been given the wrong ones,
apparently there are 2 cap dia's 1 1/16" and 1 3/16" i need the larger, still not certain though and looking for clarification.
for my 94 with 4x4, i believe i ended up going with the Dana 5-1310X for the 3 ujoints. Carrier bearing PN: HB88107A
cheers!
Yeah, I'm not up on part numbers or I probably would have helped before...
The auto parts stores have jumbled data on front axles and a bunch of stuff, mid '90 to '97 is always the bigger U joints and wheel bearings and stuff... they seem to think that Explorers had a Dana 28 at some point which never happened...
Happy to have a masters in ujoints series and cap dia to find out my ranger has 2 1350 series 1 3/16 cap dia at each wheel
And 1 1310 series in mddle which i havecnot seen anywhere ?
  • 2 piece Dana 35 ujoint and ds support bearing sanity check
There is a mod some people have done that uses D44 outer end parts on the D35 axle assembly. I wonder if someine previously did that on your truck and you may find other parts that are different.
I think mine are the 5-760x which has the groove for the retaining ring to go inside the ears of the yokes. It crosses to the standard 1310 size. I believe there is also a regular 5-760 joint.
greasable non greasable.
those are 760 joints. dana 44 or 35.
the op for rear shaft is either 1330 or 1310.
just now coming back, what a fiasco. parts store has no clue , but possibly has been answered above! checking 760 lead now
Don't go to the parts store asking for 1310 u-joints. Nobody will know what you're talking about. It took me forever to figure this whole deal out - 1210/1310/1330/1410 etc mainly refers to the trunnion/cross/x/center piece that the caps ride on. 1310 for example is a "series" where the same trunnion is used on multiple parts that have different caps and different part numbers.
