2" coil spacer results
skullet
So I finally got my 2 inch coil spacers from doetsch http://www.doetsch-shocks.com/ installed on my 2006 xlt to level the front end.
before.
After.
I went with 31x10.5 on 15 inch Dick Cepek DC-2's.
sharp looking truck. which lift did you use? have a part number?
I can't remember the part number, the coil spacers were part of a lift kit for a 2000. I just called up and told them I only needed the spacers which cost 80.00 shipped. And yes that is a mazda truck bed.
thanks skullet, I'm gonna give them a call and get those that's the exact look i was after
Awesome, be careful doing it those springs are dangerous. There are a few threads on here that explain what you need to do if you don't know. Let me know how it goes, and if u need any info pm me.
Thanks for the comments. I wouldn't of been able to do it without the ranger station community
skullet, tks for the heads up, i just helped my neighbor do a set of spacers on his grand Cherokee so it should be the same concept. i have the spring compressors already so all i needed is the spacer..
Add a 1in body lift and that truck will look perfect. And too bad you guys don't have the TIB suspension. When you take that apart, the coil spring flops out. No coil spring compressors needed. :thefinger:
I do like that, Bro!!!! The cats and I say....'Meow'!!!!!! The wheels add a clever look to the white paint!!!
:icon_thumby::icon_thumby:
