marvilusone
Where can I find either factory STX drop brackets or similar strong 2" brackets? Has anyone made a custom set that would be interested in making a second set or sharing the plans with me?
Another thread here in the TRS forum suggested using SkyJacker 132x coils rather than leveling spacers. The guy sounded like he knew what he was talking about, but after installing the new coils, my truck had a severe/dorky/embarassing positive camber issue.
autofab.com makes a stx like bracket
jamesduff's 3.5 inch brackets are very close to the stx brackets
Did you also do the required change of the camber/caster bushings?
BTW - the 132x springs do ride better. I'm sure I will get this dialed in, but I am disappointed with the install shop's understanding of adjustable camber bolts and TTB.
Since putting those brackets on, you may want to also install a standard dropped pitman arm on it.
