2.9L Ranger 4X4
xxZestxx
Got no spark, ive changed Ignition Control Mod, ECU, Dist Cap, Rot Button, Coil. Turns over fine, but no spark, wont even try to crank. I'm kinda lost here, any help would be great.
Hello
Can you pull the codes from the computer? What were you doing before this problem started? Do you have another coil to test with? Is everything plugged in?
Just asking because sometimes the problem is an easy fix.
igiveup
First thing I would do would be disconnect and then reconnect a couple times, all the connectors on the motor wiring to insure good connections, be sure to check the ground wires, then check the distributor for tightness. If it's loose, doesn't take much for it to be off enough to not start..I thought I wasn't getting any spark on mine, had a plug out and grounded, and could not see any spark, but when I checked with the volt meter, I was getting juice to the coil and dist. Timing was just off a little...
