2.9L external dimensions
Eagle_Scout2002
Spokane, WA
I was wondering if anyone had any external dimension measurements on the 2.9L? Also the of the transmission and t-case. I tried searching and could not come up with a anything that has any of the external dimensions listed. Looking for the measurements for an engine/trans swap that I will be doing once I get the engine/trans. Wanting to start preping things for the swap by seeing what all I will have to move/adjust to make it fit. The engine/trans will be going into a 1962 Scout 80. Thank you all for your time.
Ray
I'm not sure of the dimensions of the engine, but the transmission lengths can be found in the tech library.
How about the approximate weight of the engine and transmission? Thanks
Ray
