belovedb2
- Jun 17, 2009
I am doing the 4.0L swap and in the process of removing the 2.9L engine. It's a manual trans. The shop manual says to remove the clutch housing bolts, which I have done, and remove the hydraulic clutch hose. I am assuming that they are talking about the hose to the slave cylinder but I can not understand how this is accomplished since I can not even see the attachment point. The shop manual shows a clip so maybe it is a blind operation. Any Help???? When removing the engine does the slave cylinder stay with the housing or does it come out with the engine/clutch assy?
