2.9 with cracked heads
HondaEater
:bawling:how likely is it that the block is warped as well?:bawling:
Probably not. You aren't planning to fix it are you? I think you could get new heads for $500. Used ones wouldn't be worth the risk. A used engine might be worth the risk if you got it cheaply enough and are handy at swapping engines.
A 4.0 has better parts, is a lot stronger, is a difficult, but very doable swap.
Im having trouble finding running 4.0s in my area, plus I have a mitsu 5 speed in my ranger
I would just swap the heads and call it a day. As long as you didnt run it long like that, that is.
Just get some cheap oil and flush out the nastiness the best you can.
