89 bronco 2, auto trans, manual t case
I just got an 89 b2 thats obviously been neglected.
New fuel pump, filter, plugs, wires, cap, rotor, set timing.
It starts and runs ok, bit of a miss at idle. If i slowly press the gas it revs fine.
If i open throttle quickly it boggs and coughs, If I power brake it will miss pretty bad. it does seem to run a little better warm than cold.
I cant seem to locate a map sensor, tps voltage seems to move smoothly as throttle is opened.
I just put a another fuel filter on it, the one I took off that was a week old was full of rusty gas.
I pulled the injectors and sprayed them out with carb cleaner, that seemed to help for a few minutes.
So, I guess what I am asking is should I go after the fuel system and replace all of the fuel lines front to back and clean fuel rail and injectors or is there some other engine management sensors that need to be checked first. possibly O2 sensor?
Thanks
Thanks
