born ford
Ok, just finished rebuilding my 2.9 with mild overhaul, i am getting alot of noise out of the top end . Sounds like a diesel! I cold set the valve lash as per the chilton manual but it sounds like the lifters just wont pump up . motor sounds good through out idles fine and revs fine. its pumping oil like mad from the rockers so i know the pressure is good. what could be the issue?
this is a list of what i did while it was apart:cleaned it(alot of sludge) one bad head and the other checked out good, bought a new head. new gaskets all around,had some collapsed liters so threw a new set of lifters in on the old cam, I know i should not do that but im on a budget,and needed my truck back.
